The worlds ugliest/most expensive homemade tig pedal ever made
发表于 2021-8-31 22:18:40 | 显示全部楼层 |阅读模式
Well like the title is supposed to say lol most expensive homemade tig pedal here we are. Made a tig pedal after the other one i had made previously craped out. Why is it so expensive you ask well i have a micro switch from a uh1-Huey as my lift trigger and a tach generator drive gear shaft from a lycoming t55-08d turbine engine. Seems to work ok it was a bit of a bear to keep tension on my chain and still return the pedal to a heel down situation Dont look to close tho lol its just a pile of scrap lumped together to get my old lincoln tig up and runningEdit: sorry cant edit titleLast edited by waspjr123; 09-18-2014 at 01:56 AM.Using Tapatalk
Reply:waspjr123If - Back to the Future 1.4 is ever made - you have a lock on the pedal for the 'Flux Capacitor'.http://en.wikipedia.org/wiki/Back_to_the_FutureOpus
Reply:Thats cool!!
Reply:Fixed your title for you..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:As long as it gets the job done.
Reply:I love it!Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Tim the Toolman would be proud of that."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Captain Morgan would love it.  Thanks for showing it.
Reply:Aircraft parts give it sex appeal and bad-***-ed-ness!GravelThe difference between theory and practice is that in theory there is no difference.
Reply:"Steam Punk Pedal"Giving Mario a run for his money. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I will not dispute your claim!
Reply:Very nice, what is the resistance value of the potentiometer?Mastering others is strength, mastering yourself is true power.
Reply:looks kinda like a foot pedal to a drum set. very resourceful.i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by waspjr123. . . i have a micro switch from a uh1-Huey as my lift trigger and a tach generator drive gear shaft from a lycoming t55-08d turbine engine.
Reply:Originally Posted by DSWFixed your title for you.
Reply:Its a 5k 2watt pot from a amplifierUsing Tapatalk
Reply:If you get tired of it, IronHeart_Ram wants it for his next sculpture MillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC"I'd like to believe as many true things and as few false things as possible"
GMT+8, 2026-1-1 21:12 , Processed in 0.098756 second(s), 18 queries .
