My air compressor that runs off the engine broke off the other day. Vibration was to much and it caused the cracks to weld. I did not use a hindge style. But because the belt tensioners on my older truck are near impossible to find and if, I want to have these compressor mounts sold to the 4x4 market, It would be best to mount the compressor, a york 210 be mounted on a large hinge. The other side would be bolted upto the side of the engine block.The thickness would be 1/4 inch machined or stamped. It has to be beefy because of the normal vibration these engines produce at idle. I may have to weld one side of the hinge to the mount plate for the compressor. Again, the compressor base is approximately 6 inches deep. So if the mount can be this wide and really heavy duty, that would be great!
Reply:Why not make a hinge?A simple piece of solid round stock, and a piece of pipe. Much like a small trailer uses for the fold up ramps.I do not have a good pic of mine, an cannot post one right now anyway. However I know there are pictures here, I will see if I can find one for you.
Reply:Here is an idea I have not seen before, thing you would be a bit better with what I was thinking though.http://weldingweb.com/vbb/showthread.php?t=99271Not the best picture, but you can see the hinge's just pipe and round stock.http://weldingweb.com/vbb/showthread.php?t=24847
Reply:How about a tubular type weld on hinge with the brass bushing? Relatively cheap, maintenance free and very strong. They are easily found online, here is the first one on a search:http://www.hoffmanhinge.comSome of them are remove by sliding to one end but it would be easy to make a little "keeper" to prevent that. "Anybody can talk $h!t behind a monitor, I let the quality of my work speak for itself"Lincoln Square Wave 255 and 355 Tig Lincoln 255 Power-Mig w/ spool gun Koike 5 x 10 CNC plasma Hyd-Mech DM-10 bandsaw Ineco QB-76 NC tube bender
Reply:Northern tool has bullet hinges and if you look around there are some that have a zerk, too.http://reviews.northerntool.com/0394...ws/reviews.htmGood Luck on your project.TxDoc's Photos Lincoln SP175 PlusLincoln Power Mig 256Lincoln 250 LX Spool Gun Lincoln Precision Tig 225 Hypertherm 600 KMG 2x72 Belt GrinderBaldor 812RE Grinder
Reply:" solid round stock, and a piece of pipe "1/2 right, the solid round stock is good, normal pipe is not unless you have a lathe, pipe has a welded seam inside and donks up hinges, use DOM tube no inner weld seam and is heavier wall than pipe.For a 1/4 wall and a 1/2 inch pin a 1" DOM is what your looking for. |
