Lincoln Cover
发表于 2021-8-31 22:18:30 | 显示全部楼层 |阅读模式
Hey guys,I just received a Lincoln Canvas Cover for my new Lincoln Ranger 250 today in the mail. (Want my machine to stay shiny as long as I can anyways) The cover has 6 holes for securing it in place.It did not come with instructions or suggestions on the best method to do this. Has anyone done this before and if so, how do you keep your cover on your machine so it won't go flying away when on the road? Thanks,JoshLincoln Ranger 250- Kohler 23hpVictor SuperRange II torch03 Ram 3500
Reply:I'm thinking of just bolting down some D-rings at each point where there is a ring on the cover. It'll be a little more time consuming to install them, but I guess it'll be worth it in the long run.Lincoln Ranger 250- Kohler 23hpVictor SuperRange II torch03 Ram 3500
Reply:Originally Posted by newI'm thinking of just bolting down some D-rings at each point where there is a ring on the cover. It'll be a little more time consuming to install them, but I guess it'll be worth it in the long run.
GMT+8, 2026-1-2 00:35 , Processed in 0.107358 second(s), 18 queries .
