SA200 diesel conversion??
发表于 2021-8-31 22:18:28 | 显示全部楼层 |阅读模式
Anybody do or have links to a SA200 Yanmar or other diesel conversion, I know Hybri weld may have it but is probably quite espensive?"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:The Yanmar 4TNE88 or 4TNV88 is what some dealers in TX, LA, & AR have been putting in them for a while now.  It is rated to pull a generator load at 1500 to 1800 rpm and has already been proven in welders.  I don't know how much the engines cost but most of that depends on the quantity the dealer they buy from sells and your location.  The Yanmar flywheel has to be remachined to make it work and refit into the frame of course.   Yanmar is a popular conversion for marine too now so check with some of those dealers in your area.   http://www.americanweldingsupply.com/specials.phphttp://www.yanmar.com.au/industrial/...ies/4tne88.htmYanmar also builds some high frequency portable welders now that use no brushes.  I haven't see any being used yet or heard anyone over there talking about them yet what those are like.  http://www.yanmar.co.jp/en/powerprod...s/ytw-300.html
Reply:Here is a discussion that might help.  Check it out.  -Rhynohttp://weldingweb.com/vbb/showthread.php?t=3780807 Fowler 200D65 RedFace04 Miller TB 302, 22hpMiller 12RCMiller HF 251-1Lincoln SP135HyperTherm PM 380and a few others... Originally Posted by RhynoBut, if I "all of a sudden disappear....  ...." hopefully I didn't suffer too much....
GMT+8, 2026-1-1 21:13 , Processed in 0.070728 second(s), 18 queries .
