Industrial Style Coffee Table
发表于 2021-8-31 22:18:27 | 显示全部楼层 |阅读模式
This is the first coffee table I have built.  Hoping to sell and build more furniture in the future to put up for sale.  Trying to mix industrial and rustic into my designs. Attached Images
Reply:Looks good!
Reply:Absolutely beautiful.  Great job.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I love it , i might even have a bash making something similar, its really rustic and if you use some recycled timber then you've got the best of both worlds'Been looking at making something like this for agesEasy to make and does give that rustic, industrial look which so many people like these daysLast edited by Gerry1964; 10-19-2014 at 12:25 PM.
Reply:very nice work. i was trying to figure where you were located till i saw your screen name. shipping would be murder.Last edited by docwelder; 10-19-2014 at 02:50 PM.i.u.o.e. # 15queens, ny and sunny fla
Reply:Very nice!GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Really nice stuff there. I love the contrast of the black and wood tone. Never would have went there on my own. I will definitely experiment with that kind of look. Thanks. Years ago grey and burgundy became two very popular colors and again I never would have thought of it. But seeing them together changed my point of view for sure.                       Sincerely,                            William McCormick
Reply:dakotarich024Your design can look good anywhere due to its inherent flexibility: of size, color and wood. TIG or wire - coped or mitered?Paint or powder coat - and what kind of wood?Opus
Reply:Mitered corners, MIG, Painted (many coats), Cherry wood with about 6 coats of PolyYour design can look good anywhere due to its inherent flexibility: of size, color and wood. TIG or wire - coped or mitered?Paint or powder coat - and what kind of wood?Opus[/QUOTE]
Reply:Thanks Everyone for the comments!  I appreciate it.  The table is 48" long, 24" wide, and 19" tall.  The wood is 1" thick cherry with 6 coats of Poly.  The frame is 1 1/4" x 11/4" and 1/8" thick.  The rails between the wood is 1' x 1" also 1/8" thick.  The frame is mitered cut corners with 5 coats of paint.
Reply:Cherry and black steel - my favorite combination - nicely done Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:That is a beautiful table. Nice wood. Excellent craftsmanship!Old tools, trajan band saw, grizzly, delta,lincoln
Reply:That is a beautiful piece. I like the clean lines and smooth transitions between materials. As others have noted, and I agree, wood and metal can go together very nicely if done with good taste; I think that you nailed it.-Niche
Reply:Beauty man! Great job!I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Beautiful. How does the wood stay in, is there a lip on the bottom?www.FirehouseFabricators.comZachLincoln 210mpLincoln SW200Hypertherm Powermax 45xp2x4 CNC Plasma Table.
Reply:Thanks everyone!  There is 2" flat bar welded to the rails under under the wood (one on each end and one in the middle) that supports the wood.  The rails in the middle is 1" by 1" and the outside rails are 1 1/4" by 1 1/4".  The wood is also 1" thick so the 2" flat bar is hidden on the outside rails and are then welded onto the bottom of the 1" by 1" rails.  The wood is then secured by screws throughout the flat bar.  Hopefully that makes sense.
Reply:Really nice clean look!  Bet you won't have any trouble selling it!
Reply:Awesome! "Hey I didn't come to look and learn, I came to turn and burn.... If I can't light up, I'm gonna light out!"-JodyIdealarc 250 "Fatman"MM 252MM 211 "Little boy" Victor Torches
Reply:Outstanding metal/wood project.  Genius work.PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Great job. I wish you would take a picture of the underside.
Reply:Here is a new sofa table I just finished.  It is made from reclaimed douglas fir. Attached Images
Reply:I will get a pic of the underside of the table when I get back into town next week
Reply:Out of curiosity how do you grind all the seams flat without it showing any through the paint?www.FirehouseFabricators.comZachLincoln 210mpLincoln SW200Hypertherm Powermax 45xp2x4 CNC Plasma Table.
Reply:Originally Posted by BrooklynBravestOut of curiosity how do you grind all the seams flat without it showing any through the paint?
Reply:I use a grinder to remove the bulk of the weld, then switch to a 60 grit flap disk then a 120 grit flap disc.  Then before paint, I skim coat the areas with bondo just to fill in any irregularities.  When the bondo dries I sand everything smooth.   Hope that helps.
GMT+8, 2026-1-1 23:12 , Processed in 0.123404 second(s), 18 queries .
