new welding table modification?
发表于 2021-8-31 22:18:26 | 显示全部楼层 |阅读模式
I built myself a 4'x6' x 1/2" welding table last wk. I have a job for myself coming up where going to tack and weld about fifty pcs. of tubing to make an "L".Is there any reason I shouldn't cut the corner off my table and hang the tubing off the corner to weld them up? I know for a fact that the table is perfectly square. So I was going clamp the tubing to the edges then weld. Is there any reason I will regret not having a sharp corner on the table in the future?
Reply:Well... It's metal. Anything you cut off of the table can be welded back on. Just a thought
Reply:I can't see why you would want to cut your table  just draw a curve on it www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Thought I could clamp the tubing to the edges then weld the mitered joint at the rounded or cut corner and get to all 4 sides welding it in place then unclamp in one operation. Sorry should have said 2x2x1/8" rectangular tubing.Last edited by Crete; 11-08-2014 at 06:06 PM.
Reply:It actually sounds like a nice feature to me.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Get a welders angle clamp and it will pay for it self in no time. http://www.amazon.com/Bessey-WSM-9-7...=vglnkc5587-20
Reply:Originally Posted by BD1Get a welders angle clamp and it will pay for it self in no time. http://www.amazon.com/Bessey-WSM-9-7...=vglnkc5587-20
Reply:Originally Posted by GravelI have one of the Northern Tool models of this and it works well too but at half the price. I can't really compare them because I don't have a Bessey. Probably the difference between German and Chinese made...
Reply:Originally Posted by BD1Either one will make that sooooooooooooooooooooo much easier !!
GMT+8, 2026-1-1 21:11 , Processed in 0.072311 second(s), 18 queries .
