Large Concrete filled tread Staircase
发表于 2021-8-31 22:18:24 | 显示全部楼层 |阅读模式
Hi all,Here i am again with another staircase build, this time, the threads get welded to the sides of the box stringers and then filled with Polished concrete.So I started off with the 2 large Box Stringers these are 300mm x 150mm x 8mm box sectionover 8 meters long about 24 ft !! Thank god i had an overhead craneI started at the bottom and once i've marked out my angles i tack the treads on, a job like this really needs two people as the treads are pretty heavy for one man to liftLooks almost complete once a run of treads go in
Reply:Getting ready for the next sectionThe Landing Plate was a nightmare to get right as it had a slight curve to it, however tacks every 6 inches and a bit of muscle helped to get it in the right placeTreads welded from inside to startJust checking making sure all is true and levelThe bottom of the staircase will have a landing and 90 degree return flightMe welding
Reply:I laid a sheet of plywood over the tacked treads so i could lay on there and weld the insides of the treadsThats the staircase done from one side but now i need to cut it up into 3 sectionsLast edited by Gerry1964; 11-09-2014 at 12:24 PM.
Reply:I lifted it up with the crane to check my angles and made sure all the overall dimensions were correctI left 3 treads unwelded so i could cut through the stringers, Each section had to go into a lift that was only 3 metres deep, 9ftand thats those pieces cut up now into lift sized chunks lolThe bottom of the staircase i made level so i could build the return flight
Reply:and the bottom steps going in...the landing plate welded inand then the last few steps
Reply:The finished returnShould look great when its all welded up again back on site
Reply:Originally Posted by 7A749Man, Gerry you do some fabulous work!I wouldn't even know where to start
Reply:Very nice work you did there, that bridge crane is almost required for stuff like that. Is the orange color a rust preventative coating or primer?TOO MANY TOOLS & NO MORE SPACE
Reply:Another impressive build, Gerry!GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Wow! I couldn't even fit that in my shop. Nice work!
Reply:Originally Posted by Chris T.Very nice work you did there, that bridge crane is almost required for stuff like that. Is the orange color a rust preventative coating or primer?
Reply:Originally Posted by GravelAnother impressive build, Gerry!
Reply:Great work Gerry once again! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by weldermikeGreat work Gerry once again!
Reply:Gerry very nice stair case, where is it going? Also why concrete filled? For fire protection?
Reply:Originally Posted by That Guy ThereGerry very nice stair case, where is it going? Also why concrete filled? For fire protection?
Reply:Originally Posted by 7A749Seems a lot of tubing down in OZ comes with a blue paint style finish on it, and you gotta grind it off before you can weld on it.Always a pleasure checking out your work Gerry
Reply:awesome.
Reply:Very nice, man.  I just recently started learning some stair layout stuff. It's not really that complicated, just kind of a different way to think about fab work. this is a lot more complicated than anything I've done yet, though.  Cheers from Nashville.Millermatic 211 Miller Blue Fire 140@swiftwelding on Instagram
Reply:Wow Gerry   great build .  I really enjoyed getting to see all those photos.  Keep posting projects.
Reply:Thanks Guys, i will no doubt go to the site and see how its all coming together i'll stick some more pics up then !!
Reply:Nice looking, makes for a clean "weightless" look."Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2026-1-1 23:13 , Processed in 0.072330 second(s), 18 queries .
