Strange with pulse
发表于 2021-8-31 22:18:23 | 显示全部楼层 |阅读模式
Was out in the shop practicing aluminum beads with pulse about 60 cyclesworking ok But when I came into house for coffee the wife says whats going on out in the shop as the lights were pulsing  while you were welding Well I am not to worried but will check on this as the shop and house are on 2 separate lines from the meterand really should not effect the houseGuess will have to check with an electrician as to what is going ontrailblazer 302thunderbolt ac dc machine Hobart fluxcoreAHP tig 200x 2015
Reply:Possible RF or HF interference?Put the wire in the fire!Lincoln AC225 | Lincoln ProMIG 140 | AHP AlphaTIG 200x | AHP AlphaCUT 60 | Millermatic 251
Reply:I tried to get some strange with a pulse on purpose last week at the hotel, count yourself luckyExperience is something you get right after you need it
Reply:Not enough amperage coming from the pole to the meter? Could be causing voltage drop on the whole service.
Reply:trailblazer 302thunderbolt ac dc machine Hobart fluxcoreAHP tig 200x 2015
Reply:Hello akphill, even though you may be on two separate lines they may utilize a common ground and as other have eluded to, you could be drawing different levels of current when your machine is "pulsing". A common ground will essentially "connect" these circuits together and could cause voltages to fluctuate to your lighting in the house. I imagine that more electrically savvy members here can nail this down better. Best regards, Allanaevald
Reply:Does it cause the same phenomenon when on DC?If not, AC mode does not like pulse. Why are you using pulse for AC anyway?Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:No not blinking on dcUsing a little pulse on aluminum  seems to make the tig weld bettertrailblazer 302thunderbolt ac dc machine Hobart fluxcoreAHP tig 200x 2015
Reply:Originally Posted by akphillNo not blinking on dcUsing a little pulse on aluminum  seems to make the tig weld better
Reply:To add to my previous post, gas type and flow, tungsten stickout and angle, preheat, metal thickness, and travel speed also influence weld cosmetics. Generally a near vertical torch angle is optimal, feeding your filler at a 90 degree angle to the torch, cramming it into the puddle as that is where naturally seeks refuge.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Thank you for the insite I am trying to teach myself how to run the tigI will try what you are sayingtrailblazer 302thunderbolt ac dc machine Hobart fluxcoreAHP tig 200x 2015
Reply:Follow everything Shovelon says.  I've watched him weld aluminum many times and it's nothing short of amazing.  Terry has more experience welding aluminum than just about anyone on this forum.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by soutthpawFollow everything Shovelon says.  I've watched him weld aluminum many times and it's nothing short of amazing.  Terry has more experience welding aluminum than just about anyone on this forum.
GMT+8, 2026-1-2 00:35 , Processed in 0.114563 second(s), 18 queries .
