xmt 304 vs xmt 350 .. could you share your opinion?
发表于 2021-8-31 22:18:23 | 显示全部楼层 |阅读模式
hisearch function won't work on my phone so I'm sorry if this particular post has been beaten to deathI'm curious on opinions of the xmt 304 vs 350... all I'm looking for is a quality machine to practice tiging pipe in my shed and build myself utility trailers for atv or if something breaksboth are available to me right now and was curious to what people thought of one to the otherI appreciate your time for reading and ty in advance for your opinion if you post.. much appreciated. . ty
Reply:I like my 304, pushed close to 400 amps out of it air arcing a bucket. Surprized, I've never used a 350 so no answer. 304 togs well, sticks well, and runs this crap out of my voltage sensing wire feeder. Good luck.
Reply:My experience is almost identical. We're you looking for new or used. The 350 would be nice, but personally I wouldn't spend much more to get one .
Reply:Only thing is 25 extra amps as far as I know.400amps for the xmt304 and 425amps for the xmt350.Last edited by AKweldshop; 01-13-2016 at 07:29 PM.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:ty for your comments...would both of these machines run off 200 amp service in a shed? I thought I seen the 350 was 1 & 3 phase while 304 is 3 phase... I don't know much about thatboth 2nd hand machines, it would be disaster if i bought one and wouldn't run off a 200 amp service ty for posting
Reply:Both are single or 3 phase, altho I believe that there is a high input voltage model, which won't run on 230 volt. One thing to keep in mind is that they don't work well on 200-208 voltage. Also make sure you are getting a CC-CV version, since they did make a CC version in the 304.
Reply:480-525, 3phaze only
Reply:Originally Posted by Mark's Welding480-525, 3phaze only
Reply:Both are professional level machines and you intend to practice.  I think you won't notice any difference as long as you have the power to drive them.
Reply:Both are great machines. It has been a while since I used the XMT304-like years! The main difference I remember was it didn't have the advanced features of the XMT350. Like comparing the Dynasty 200 to the Dynasty 200DX. Great machine, just not as many bells and whistles! Hope this helps.
Reply:Originally Posted by M J DThat would be the high voltage, altho I believe it will run on 480 volt single phase. 480 single phase is not very common tho.
GMT+8, 2026-1-1 22:56 , Processed in 0.096783 second(s), 18 queries .
