symbol question
发表于 2021-8-31 22:18:23 | 显示全部楼层 |阅读模式
Hello everyone.can someone please help me with this welding symbol on drawing.I don't understand the 27-3 part...it can't be length and pitch nor leg and throat! I'd really appreciate the help.
Reply:46 views no one knows?
Reply:It looks like an intermittent weld is being called for. But the measurements don't make sense for that.Plus, it's a groove weld, which also wouldn't make sense.Typo?Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Size and depth?First guess would be length and pitch as well. Maybe wrote in mm?Symbol looks weird to me. It's wrote on other side of symbol but the v groove doesn't coordinate with that.
Reply:I'd just guess it means 3 passes needed?12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:it looks like that little flag next to the 27-3 it is making reference to side notes else where on the plans,Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:I thought flag meant field weld?
Reply:im just guessing.....Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:thanks for the replies.I thought it was weird as well..this symbol is all over the drawing (bevel as well ) with another one being 15-5...looks like they are following their own kind of standard! (magotteaux-multinational company)hopefully someone can help.
Reply:The 27-3 is a weld size the arrow is a field weld designationtrailblazer 302thunderbolt ac dc machine Hobart fluxcoreAHP tig 200x 2015
Reply:First of all, for your weld to be on top of the plate, the symbols need to be under the arrow line.Yes, the flag means field welding.If they meant flat ground finish, the line should be under the G, not the 70.Intermittent weld numbers are supposed to be on the right of the symbol.Is it possible that your plate is around 27mm thick? If so, its 27mm thick of weld, i dont know about number 3, yes it could be a number of welds.437 could be the lenght of the weld?
Reply:I'm curious to read what the drafter really means with this symbol.
Reply:The weld symbols and detail are not being presented correctly. But I'll take a shot at it. The joint is a 60 degree double groove. The G above the 60 should be a number that gives reference to the root gap. It should not be a letter indicating that's is a a groove weld. The 27-3 would mean the depth of the groove (top of the plate to the top of the land) the 3 should be in brackets and indicate the required depth of weld penetration. In this case, it is not a requirement for a fully penetrated weld. As the drawing is right now, the information being on top of the reference line with the arrow pointing down tells me the weld detail should all take place on the other side of the plate. The flag does indicate it's a field weld. I am not sure what the 437 references though?JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:437 is the width of sections (overall weld length) the G is the finish (grinding).the weld has to be from the arrow side!I will get to meet a representative soon and ask him about it.thanks for all your help.
Reply:That is a tough one... But I'll take a stab at it..Field weld, 27mm welds in 3 places, 60° V ground flat and the weldments are 437mm apart, and use low hydrogen rod.The writing states: weld on the perimeter ringwelding the peripheral areas..for whatever that's worth.Common sense in an uncommon degree is what the world calls wisdom.
Reply:To dig this one up again.. What was the verdict?Common sense in an uncommon degree is what the world calls wisdom.
Reply:I don't believe the OP is ever coming back.
Reply:One thing for sure is this I is an ISO  symbol(international standards organization). I have seen this before.  They basically hijacked the AWS style and "Made it Better" One would need to buy or download the chart to decode the symbol.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Originally Posted by shovelonOne thing for sure is this I is an ISO  symbol(international standards organization). I have seen this before.  They basically hijacked the AWS style and "Made it Better" One would need to buy or download the chart to decode the symbol.
Reply:Thanks!Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
GMT+8, 2026-1-1 21:13 , Processed in 0.097475 second(s), 18 queries .
