Need bulk 3d plastic washers for key lock assembly
发表于 2021-8-31 15:01:56 | 显示全部楼层 |阅读模式
Like this Maybe 500 pieces to start. Inserts in molded control case and keeps the lock from turning due to the flats on each side. 3/4 dia. -/+ 1/4 thick I can make a proper drawing.Gouse under the chrome lock ring(hole in case too big
Reply:A cheap 3d printer could turn them out for ya' and be plenty strong for the intended use, of course it wouldn't be all that fast but probably cheaper than regular injection molded parts unless you can find and existing part that would fit the bill.
Reply:If you are fine with them being 3D printed, I can get them made in any color of ABS you would like and it would take me about three days to get through 500. We can talk dimensions, tolerances and pricing. Shoot me an email at [email protected] edited by Joseph_F; 10-31-2019 at 12:00 AM.
GMT+8, 2025-12-18 16:17 , Processed in 0.101627 second(s), 18 queries .
