Is there any way to know what the tap settings on a Lincoln 180 convert to in volts?
Reply:Clip the meter on the studs while welding is about the only way I know.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:call Lincoln and ask. They'll tell you the approximate voltages. Did that for the little 140 I had and they were more than happy to provide the information.
Reply:I'm by no means an expert having only been at it a year or so but I've learned that nothing in welding operates in a vacuum. Everything is inter-dependent on other things like wire speed and the like. There's an article I found that helped me alot.http://www.gowelding.org/Settings_MI...ng_Charts.html
