Cold metal saw - should I buy it?
发表于 2021-8-31 22:18:12 | 显示全部楼层 |阅读模式
Hello all,since my old abrasive cut saw broke I am searching for a replacement and I have found this cold saw for 250€.http://www.bolha.com/obdelava-kovine...glas1279571918I talked to seller and this cold saw is custom made from avtomotive parts, it has worm gear, 4 speeds. For that price i would get saw as you can see on link above (with stand), two new HSS saw blades D250mm, additional unnused worm gear with 4 speeds and emulsion concentrate. It has 3-phase 1kW motor.The saw is about 10 years old and it was used as afternoon busines for making fences so i guess it was not used that much. He is selling it because he bought a new band saw.What do sou think? Should I buy it?
Reply:interesting build, appears to be good quality, how available is that power to you?Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:how available is that power to you?
Reply:Hi all,i have bought cold saw that in mentioned above and even completed my first project with that saw and all I can tell is that it is great! I am sorry for every € that i had spent for those crapy Made in China abrasive saws. No more dust, hot pieces, deburing ... Despite that coldsaw is home made i works great!Here are the pictures if anyone is interested:I also got two new blades, worth 80€ each and extra gearbox. I was told that it is form a scooter. I opened it i found out that it has no worm gear like most of saws but it has ring gear and pinion. On pinion it has 4 four speed gearbox. http://toyheadauto.com/PerformancePa...ing_Pinion.jpgActually I have most of parts for building another cold saw, just need motor, coolant pump and frame.Here is my first project with new cold saw, sheet metal storage rack. I dont have build pictures because my phone battery was to empty to take pictures (that hapens a lot of times ) and I was so into the building I did't want to stop to get a charger! Cheers!PS.: I made a mistake buying soft rubber wheels. I can barrely move it. I should buy hard rubber wheels.Last edited by T_Eclipse; 05-08-2012 at 12:09 PM.
GMT+8, 2026-1-1 21:13 , Processed in 0.096360 second(s), 18 queries .
