Tig wiring for 110v help
发表于 2021-8-31 22:18:10 | 显示全部楼层 |阅读模式
Hello,I have a 220/110v tig that purchased several years ago. Right now it have a 220v plug on it with the wire colors being Black, Green and Yellow. Green was ground and black/yellow were the hots. I need to switch the plug back to 110v as i no longer have 220v where i moved. Where do each wires go? I know this is a dumb question, just dont want to hurt my machine by guessing.Thanks, Luke
Reply:i posted this in the wrong area. Could someone move it to the correct one, as i need an answer quickly. Thanks
Reply:Knowing what machine you have might help. My crystal ball is out right now being polished..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Thermal Arc 150gts. the owners manual doesnt tell you how to hook it up.
Reply:on the plug you will have a brass screw and a silver screw and a green screw. black wire to brass yellow wire to silver bare wire to green ground. 3 wires right? inverter?
GMT+8, 2026-1-1 21:10 , Processed in 0.100888 second(s), 18 queries .
