Ideal Arc SP-200 wire feeder motor
发表于 2021-8-31 22:18:08 | 显示全部楼层 |阅读模式
wondering if anybody would know where i could pick up a wire feeder motor for my old idealarc.  Seems to not be easy to find.  Bought it all used off a buddy few months ago.  The feeder had been removed and put onto a cart which worked fine, but the motor started kicking out the breaker and running inconsistently.   Replaced the brushes, still keeps kicking out.  Bypassed the breaker, (not recommended) and stuff started getting warm.  The motor is shot Im sure.  This thing has been around a while.  Thanks.  Chad
Reply:Have you tried your local welder repair shops? My guy has a lot of stuff. You want me to check around here?Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
GMT+8, 2026-1-1 21:10 , Processed in 0.100621 second(s), 18 queries .
