Lincoln 180 from Lowes
发表于 2021-8-31 22:18:08 | 显示全部楼层 |阅读模式
I am thinking of purchasing a Lincoln 180 at Lowes and was wondering about the electrical hookup. I cannot tell from the pic if it comes with any kind of pigtal or 220 plug or will the wire and plug have to be purchased seperately?I will be welding auto body panels and will probally need about 30 feet of cable.What size of cable should I purchase to run the welder from 30' ?ThanksNew WelderRodney1963.5 Galaxie Fastback with a 4 sp.
Reply:There is a molded connector on the the end of the power cord.  You'll have to get the mating recepticle.  I use #10 AWG as an extension.  I've had mine for a couple of years now and have been pretty pleased.
Reply:The unit comes with about 5-6' of electrical input cable with a 6-50P (plug) installed on it.  Pick SO cord for your extension of a size of around 10/3.  Dont use "ROMEX" as it is not designed for this use.  Welcome to the forum!A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:http://www.sportsmansguide.com/net/c...3&kwtid=304485or you can make one, look for the 220v Extension cord thread but the 59.00 bux for the pre-made one is a good price as it has Molded endsEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Broccoli1http://www.sportsmansguide.com/net/c...3&kwtid=304485or you can make one, look for the 220v Extension cord thread but the 59.00 bux for the pre-made one is a good price as it has Molded ends
Reply:Thanks Guys for the info the one online price is great.
GMT+8, 2026-1-1 23:13 , Processed in 0.263044 second(s), 18 queries .
