these two machines look the same....is there much difference.?spotted a couple of deals , just wondering which one to consider. thermal arc 252i - millermatic 350P - miller XMT, cp300ts, 30a 22a feeders, buttload of other millers, handfull of lincolns, couple of esabs - Hypertherm 1250 G3
Reply:Plus is Continuous Voltage selectionT Models are tapped Voltage.T should be cheaper.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:thanks brocolli , i finaly figured it out , had to google for about an hour , could'nt even retreive the info from lincolnelectric.com , seems the new 140 model replaces these.so what i've concluded is , the 135T has 4or5 amperage settings and the 135Plus has a continuous Amperage RioStat type control..? (kinda like infinate from 25-135)either way bothe deals are gone on CLperfect little bodyshop machines. thermal arc 252i - millermatic 350P - miller XMT, cp300ts, 30a 22a feeders, buttload of other millers, handfull of lincolns, couple of esabs - Hypertherm 1250 G3
Reply:They have the manuals at the Lincoln site.Also the 135 T is the same machine as the Weldpak 135 sold at the Box stores so if you see one of those on CL don't be afraid to buy it. They usually sell for cheaper since they have the Stigma of being a Cheaper machine because they are sold at the Box stores but they be the same.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge |
