dri cut saw and reversable 45* angle
发表于 2021-8-31 22:18:05 | 显示全部楼层 |阅读模式
Are there any brands of chop saw, weather abrasive or carbide tip that you can switch the 45 angle both ways? I know it sounds like a no brainer just to turn the piece upside down to made the matching cut. I was trying to cut some 2"x2" angle and not have the saw cut though the flattest part. To make proper use of the blade on my carbide tipped saw. Looked like I can move the adjustable side of the clamp, but then the hand crank side won't grab the work piece properly. Thanks
Reply:Take a look at an Ellis band saw.
Reply:First thing I did with my chop saw was trash the stupid work clamp.  They just flat suck.  I use a c-clamp directly attaching the workpiece to the fence, it works at any angle, and is very solid.  Takes a few seconds more to tighten it, but it's worth it."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by walkerTake a look at an Ellis band saw.
Reply:On my Makita chop saw when doing any cut other than a 90*, I use my visegrip C-clamp to hold it tight against the fence. With out it it tends to creep causing a crooked cut.                                                       MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:My RAGE3 goes both ways. GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Originally Posted by GravelMy RAGE3 goes both ways.
Reply:Just bought my saw from Northern Tool. Thought I did my research but I didn't notice that the Rage 3 swung both ways. Damm
Reply:When you cut angle and turn it over use a piece of square tubing under it and you can clamp it fine.DIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
Reply:Originally Posted by CreteJust bought my saw from Northern Tool. Thought I did my research but I didn't notice that the Rage 3 swung both ways. Damm
GMT+8, 2026-1-1 21:10 , Processed in 0.105888 second(s), 18 queries .
