Aaaaaarrrg!
发表于 2021-8-31 22:18:05 | 显示全部楼层 |阅读模式
I broke my best 1-8 tap!That is all. Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:50N brazing alloy, braze a nut to it.  Problem solved.Well since it's a through hole and it's big, just blow it out of there with the torch.
Reply:That sucks Robert!Going to tig a nut to it?Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:That's a big tap to snap. Next time try not running it in with the 3/4" drive ratchet wrench. .No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Cheer up mate, it could have been a high dollar part.
Reply:How in the world did you break that? I hate to see good tools break, that's why my taps are cheap garbage ( most of them anyway).Thermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:There no more sickening sound than that of a tap breaking.Ranger 250 GXTSmith Gas Axe
Reply:What were the first three words out of the mouth after the snap?That sucks!
Reply:Originally Posted by MrLeadManThere no more sickening sound than that of a tap breaking.
Reply:Hey Robert.I'll sell you a tap.I got plenty.
Reply:That is a couple. I got a couple thousand and still come up short at times.
Reply:Gloating over your recent robbery, aren't you?  Don't see many 1/8" in that fine collection.Jerry30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Originally Posted by storemanGloating over your recent robbery, aren't you?  Don't see many 1/8" in that fine collection.Jerry
Reply:Originally Posted by DSWThat's a big tap to snap. Next time try not running it in with the 3/4" drive ratchet wrench.
Reply:Originally Posted by VPTWhat were the first three words out of the mouth after the snap?That sucks!
Reply:Originally Posted by AKweldshopHey Robert.I'll sell you a tap.I got plenty.
Reply:I burned it out with the tig. All good. ... I found another.  Still.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Originally Posted by Robert HallBastard!
Reply:There's 5 or so 1" 8tpi taps in there.All greenfield morse or other old USA made ones.I'm Thinking of selling the whole lot.Any quick appraisal on them?
Reply:Originally Posted by AKweldshopThere's 5 or so 1" 8tpi taps in there.All greenfield morse or other old USA made ones.I'm Thinking of selling the whole lot.Any quick appraisal on them?
Reply:Originally Posted by GravelHow did you do that? I have a 3/8" tap broken off in 1/2" plate and haven't tried anything yet since it isn't in my way.
Reply:Originally Posted by Robert HallI'd be a bit nervous about a tap that small.  How critical is the piece is stuck in? I just put the tig up to 200 amps and zapped the center. It fell right out.
Reply:oh the hours I spent in my earlier years (maybe last month?) trying to figure out how to remove broken 1/4-20's from stainless. . . . .AND NOBODY EVER SUGESTED TIGGING THEM OUT! I like that, I think im going to create a situation and see how that works!I cried for an entire weekend once trying to remove a broken "easy out", from a broken bolt, in an aluminum manifold that would almost literally take my life if I incurred any "broken" on it. the joys of hardened steelsbosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevinI always think of fire as a solution to any problem!Then I try to think better. lolI suppose, Gravel, in this case you could tig it out, if it failed, that you can always weld up again and redrill then try it again.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Originally Posted by 92dlxmanoh the hours I spent in my earlier years (maybe last month?) trying to figure out how to remove broken 1/4-20's from stainless. . . . .AND NOBODY EVER SUGESTED TIGGING THEM OUT! I like that, I think im going to create a situation and see how that works!I cried for an entire weekend once trying to remove a broken "easy out", from a broken bolt, in an aluminum manifold that would almost literally take my life if I incurred any "broken" on it. the joys of hardened steels
Reply:Originally Posted by mikecwikUsed taps and the ones looking like them do not go for much. I find it curious a metal worker not wanting taps and dies.
Reply:Problem solved...Last edited by Robert Hall; 11-08-2014 at 12:40 AM.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Awesome Gotta love power like that Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by Robert HallI broke my best 1-8 tap!That is all. Attachment 802181
Reply:Originally Posted by docwelderpm me your address. one on the way gratis. i have several.
Reply:I resurrected my own thread.  Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Originally Posted by 7A749I was gonna say, I think I got a couple extras laying around, but DOC beat me to it.Dummy me, I just realized this thread was months old
Reply:I just thought it was the appropriate place to post the vid. Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Take a dremel with those tiny cut off wheels, you know the ones that do more exploding than anything lol, and put a slice into the top of the tap like this - then use a screwdriver and a vice grip and work it back and forth to free it up then back it out.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by weldermikeTake a dremel with those tiny cut off wheels, you know the ones that do more exploding than anything lol, and put a slice into the top of the tap like this - then use a screwdriver and a vice grip and work it back and forth to free it up then back it out.
Reply:What percentage of thread were you going for? What size drill did you use?Today most guys do not even go 80 percent anymore.                       Sincerely,                            William McCormick
Reply:I switched to taper taps for free hand tapping. I put them in some electric device, anything that will turn them, and just tap away. I also like gun taps but you can break those off. The taper taps just keep cutting and they just do not break. I get mine from my friend a machinist, he gets them with a six inch extension, It takes up the sudden binding and it just keeps cutting at rather high speeds. You do have to use sulfur-rated cutting oil.   I use gun taps in the auto thread-er.                       Sincerely,                            William McCormickLast edited by William McCormick; 11-08-2014 at 06:45 PM.Reason: Corrected spelling from "tapper" to "taper"
Reply:I made a quick movie so we can all be on the same page about taps. The taper tap in the movie is made to be driven into the work, you just power drive it right through steel, just like a gun tap. You do not stop and clear the bit.                       Sincerely,                            William McCormick
Reply:Very helpful. Thanks for the description.  I'm not sure I've seen a gun tap. How large can they get?Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:I really wanted to show them cutting, but I kind of ran out of time. We say blind taps, because we consider them for dead end holes or blind holes. But some people call a slight taper a plug tap, some call it a starter tap. But if we cannot run it right through without stopping to clear it, it is a blind tap or made for a dead end hole, to us. The one that I call the tapper tap, can be run right through steel. Because it only cuts a small amount at a time.  I found the gun taps up to 1" 8 TPI. These look like our gun taps, I do not use this brand though. http://www.amazon.com/Dormer-Powdere...5503119&sr=1-1Gun taps cut with the least resistance of all.                       Sincerely,                            William McCormick
Reply:The things I am calling taper taps are actually called nut taps if you want to order them from MSC. http://www.mscdirect.com/product/details/04689089The price for the 1" 8 TPI is $272 Haha. I bet you can get them cheaper, but still that is an expensive piece. They do thread well though.                       Sincerely,                            William McCormick
Reply:I have been using gun taps since I was a kid, that would be about 45 years now. They are my favorite tap. And most machinists use them, because you need them with the auto thread-ers. You just put that in a drill press and it slows down the output spindle, it threads a hole, and if you set the stop on the drill press or just manually, stop lowering the drill press, the device switches into reverse at high speed and backs out the tap like lightning.                       Sincerely,                            William McCormick
Reply:Those are a way to fast for me! I need to sweat and curse and worry longer before I finish a job...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Originally Posted by 7A749Those heads are pretty nice. I've been using my mill to tap stuff since I got it 14 years ago. I don't have a head tho, I just put the tap in a drill chuck and feed it at the mills lowest speed (75 RPM). Of course, you have to have a mill with a spindle brake for the best performance.I've broken maybe one or two taps in the thousands of holes I've done since. I've done 3/4" holes with it, no sweat.
Reply:Those are not cheap!I would love to see one in action.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Here is that video of the nut verses gun tap. At about 450 rpm you get a really sweet thread. At 1700 rpm you get some imperfections from the gun tap. But you can see how both of those taps are extremely aggressive and require very little energy. That is why you always find the gun tap or the nut tap being used by machinists with a lot of holes to thread. I think the nut tap makes a little nicer thread. But I will be honest if you find the sweet spot the right rpm for each one, they are both great taps.                       Sincerely,                            William McCormickLast edited by William McCormick; 11-11-2014 at 06:02 PM.Reason: I used a wrong term in the movie I edited the text in the movie and put a new link to it
Reply:That is a 91 percent thread, I used a number seven drill bit.                       Sincerely,                            William McCormick
GMT+8, 2026-1-1 21:11 , Processed in 0.107506 second(s), 18 queries .
