Cast aluminum welder needed in New Jersey
发表于 2021-8-31 15:01:56 | 显示全部楼层 |阅读模式
I’m working with a cast aluminum oil pan from a mid 90’s Nissan in-line 6 and need a welder proficient in cast aluminum. The scope of work is basically welding an extension off the bottom the pan to increase the capacity. I’ll machine the pan on the mill, construct the extension (tacked together) and will need it welded on. Cast aluminum has been a problem for me in the past, so I need an pro for this. It is a part that will get a lot of eye traffic, so appearance is a consideration. I have other aluminum weld projects as well, all custom motorsports stuff. Please message me if interested. Thank you
Reply:Good luck on your search - should be someone near you.If you were in MN, I would....your oil pan gets a lot of eye traffic?  You should probably keep the rubber side down Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by MinnesotaDaveGood luck on your search - should be someone near you.If you were in MN, I would....your oil pan gets a lot of eye traffic?  You should probably keep the rubber side down
Reply:[QUOTE=...your oil pan gets a lot of eye traffic?  You should probably keep the rubber side down [/QUOTE]Haha. The build it  well documented, and gets some social media attention. Every component is built to be seen, even the places where nobody but a rescue team should see. Haha
Reply:Where in NJ are you ?Airco 250 ac/dc Heliwelder Square waveMiller Synchrowave 180 sdMiller Econo Twin HFLincoln 210 MPDayton 225 ac/dcVictor torchesSnap-On YA-212Lotos Cut60D
Reply:Originally Posted by Blue2RedThank you, would totally ship the pan, but it really needs to be welded bolted to the block, as it warps bad. Hard item to resurface too. Thank you for contacting though
Reply:Originally Posted by albrightreeWhere in NJ are you ?
GMT+8, 2025-12-18 16:22 , Processed in 0.073737 second(s), 18 queries .
