dryer cord with 30 amp hubble receptacle for welder... . question
发表于 2021-8-31 22:18:01 | 显示全部楼层 |阅读模式
hiI need to make a cord to plug my welder into a dryer outlet in my sheddryer cord has red, white, black insulated wires and 1 wire that's not insulated30 amp receptacle has green screw, an X and Y, both brass screwscould someone please tell me which wires go into which hole? I thank you very much in advance for reading and thank you again for taking the time to post if you do.. very much appreciated, ty
Reply:Black and red to X and Y, bare to ground, tape up white (neutral) - it's not used.- Tim
Reply:ty tim.. very muchdoes is matter if black is in X or Y ? ty much for your quick post
Reply:Originally Posted by then3wguydoes is matter if black is in X or Y ?
Reply:ty for the help.. I've added some tags for this post, it could help someone else ty again
Reply:I'd go black to X, red to Y on principles (black/red/blue is normal phase ordering) but in 240V single phase, as others have mentioned, it does not matter functionally . . . .- Tim
Reply:in other countries wire color code is different. i would use ohm meter to confirm which wire color the center ground plug is connected too.. the ground connected properly can help you from getting electrocuted it you touch the outside of a welder as the welder shell is often connected to the ground wire.
GMT+8, 2026-1-2 04:20 , Processed in 0.099794 second(s), 18 queries .
