Dumb A$$!
发表于 2021-8-31 22:18:00 | 显示全部楼层 |阅读模式
Man, I feel like a COMPLETE DUMB A$$! Today, I was having a hard time seeing out of my hood. So finally I got frustrated to the point I had to stop and change the inner & outer clear lens'.  Well, I grabbed one Radnor, with green film on it, and one Anchor that was clear. Holy crap, I still can't see a thing. I was going crazy. So, I finally realized the problemo. The clear Anchor lens, HAD CLEAR PROTECTIVE FILM ON IT! I haven't done much welding this year, until lately, and I completely forgot about the film. Yeah, it REALLY helps to remove it!!!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:I've had a couple of students that had that happen to them. One went almost thru 6 classes before I let him try my hood and went to use his before I noticed he hadn't removed that protective film. Amazingly his skills improved dramatically when he wasn't looking thru 2 layers of that film..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:You called?Oh!  I see now that's just the title of your thread. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Happened to me a few times.I thought it was a good lense last time I used it....Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Stick-manRelax - it is only a life safety issue - if you make this mistake with a condom.Opus
Reply:Stick-man don't feel bad.  Lot's of folks have done that.I pulled a Dumb-A$$ stunt of mine a while back.  Turned on my little ESAB stick inverter, turned the amp knob to where I wanted it and started to do some welding.  The beads looked like cr*p, sputtered and belched, wouldn't keep an arc going, etc.  I re-ground the area for my ground clamp, cleaned up the jaws on the stinger, checked the cable connections...nothing worked.  I figured that the welder itself had gone bad... then I looked down at the switch panel.  It's a stick/TIG welder.  Somehow I had flipped the selector switch from stick to TIG.  Flipped it back to stick, welded like a dream!  DUHHHHHH....
Reply:Ha I was testing a TIG/stick machine a couple weeks ago. Worked fine on TIG, disconnected the leads, swapped them and hooked up the stinger.  Went to weld, nothing, switched back to TIG fine.   Back to stick, nothing.    Finally realized I was swapping the leads and hooking the TIG torch in one side and the stinger in the other.  Unplugged the TIG torch and connected the work clamp, all was good  FacepawTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:You have not cornered the market on dumb.
Reply:It took longer than I would like to admit for me to figure out my Lincoln Viking helmet at work didn't come with batteries in it. That was a rough morning.My "collection":Homemade Stick WelderVictor O/A TorchAC 225Ideal Arc 250HF 90 Amp Flux CoreHF Mig 170Solar 2020 Plasma CutterPower i-Mig 140EHarris O/A torchHF Dual Mig 131140STAlpha Tig 200x
Reply:Left Tig setting on AC and tried to do steel. Then next day forgot to turn Argon on. Getting real good grinding Tungstens.
Reply:ha ha lolLincolnlongevity200sx
Reply:Originally Posted by mcostelloLeft Tig setting on AC and tried to do steel. Then next day forgot to turn Argon on. Getting real good grinding Tungstens.
GMT+8, 2026-1-2 04:19 , Processed in 0.095986 second(s), 18 queries .
