Has anyone replaced the trigger spring on a Lincoln Magnum 100L gun?
发表于 2021-8-31 22:18:00 | 显示全部楼层 |阅读模式
Mine seems really touchy especially with gloves on. I'd like to replace it with a stiffer one but don't know if that's possible or how difficult it would be.
Reply:So easy..photo show it all..I did not replace mine but change the orientation instead..Sent from my iPad using Tapatalk
Reply:Thanks! So you used the nail file to pry the 2 handle sections apart?
Reply:By golly, that's a simply adorable little MIG gun.
Reply:Helpful comments are welcome. But if your purpose in that post was to mock someone's welding equipment, move to a different thread.
Reply:My apologies.
Reply:Nope..locks are located at both end of the handle..you just simply twist and pull and your done.Sent from my iPad using TapatalkLast edited by bugeloo; 01-19-2016 at 11:18 AM.
Reply:Great! Thank you...I'll give that spring replacement a try in the next couple days. Just curious, seems odd having the switch under one's thumb or palm. Why did you change it and how's it working out?
GMT+8, 2026-1-2 04:20 , Processed in 0.113210 second(s), 18 queries .
