Enquiry on an observation on FCAW
发表于 2021-8-31 22:17:55 | 显示全部楼层 |阅读模式
Hi guys, I had a question to ask regarding FCAW.On one occassion, I observed that a fellow senior welder dunking his FCAW welding gun into a can of white paint and he carried on his welding onto steel plates.As an apprentice, I did not ask and would be appropriate due the cultural differences.Thinking back, I am rather curious to know. I would appreciate someone who can shed some light.
Reply:What country did the cultural difference occur in?30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Originally Posted by WhitePetalOn one occassion, I observed that a fellow senior welder dunking his FCAW welding gun into a can of white paint and he carried on his welding onto steel plates.
Reply:Originally Posted by pin2hotYou sure that wasn't something like this:  http://www.use-enco.com/CGI/INSRIT?P...uJWRoCBYHw_wcB
Reply:I vote for nozzle dip.. I'd think if it was white paint it probably would have caught  fire while he was welding. But I've seen crazier things before!Real welders know how to penetrate!(Equipment)Whatever can be used to beat my opponent into submission!
Reply:Thanks for answering guys. I will try and investigate further. I was surprised to see it's white paint look a like instead of gel kind.
Reply:Some people use vegetable oil spray to keep spatter from sticking on the work.I suppose vegetable oil shortening might work as nozzle dip, thought i suspect it would burn and stink.
Reply:Could it have been white led?
Reply:In the UK we have a white spray that you spray up the nozzle, its ceramic based and designed to stop spatter inside the shroud. perhaps this was similar what you saw except in a pot??
Reply:Here it's the USA version.  http://www.henkelna.com/adhesives/lo...ions-20226.htmAbout $23 from weldingsupply.com.  was the cheapest I found itTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
GMT+8, 2026-1-2 04:21 , Processed in 0.122084 second(s), 18 queries .
