Steak pocket hook
发表于 2021-8-31 22:17:55 | 显示全部楼层 |阅读模式
Whats the best way to tig 1/8 square tube to a 1/4 plate it's steel.
Reply:Originally Posted by FlyingJWhats the best way to tig 1/8 square tube to a 1/4 plate it's steel.
Reply:Originally Posted by BistineauWith a TIG welder. That would be my guess.
Reply:I meant bevel-gap- tungstin size filler size
Reply:the square tube is 1/8" across, or 1/8" thickness.??? Are you laying it flat on the 1/4" steel plate????   Vertically????   So much missing information it's not even funny. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:18 thick and it's sitting vertically on 1/4 to make a steak pocket d ring
Reply:I put steaks on the grill, not in a pocket. Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:i don't like my steaks tig weldedi.u.o.e. # 15queens, ny and sunny fla
Reply:the hell is a steak pocket? post a pic or a drawing...i'm confused. typically you would weld it hotter, and keep your arc more on the thicker side of things...thats the best i can do for what little info i haveAHP alphatig 200xclarke 130en MIG (first welder i ever bought)NT Plasma 375craftsman 240/180 ac/dc ARCcustom 60x30x30 powder coating ovenhttps://www.facebook.com/pages/Rossi...18853401526643
Reply:Would medium rare be a cold weld?
Reply:Originally Posted by limegreentjthe hell is a steak pocket?
Reply:Originally Posted by MinnesotaDaveI think it's like a "Hot Pocket" - 1:30 in the microwave and it's done
Reply:Stake pocket. Pickup bed stake pocket.  Beware of making too heavy of a tie down for a stake pocket in a modern vehicle. They're made out of tin foil any more. Better off buying a pair of those rubber expandable inserts."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:The guy is just looking for help.Don't ridicule him.
Reply:Originally Posted by FlyingJ18 thick and it's sitting vertically on 1/4 to make a steak pocket d ring
Reply:You really don't need to TIG 11ga tubing (1/8 roughly).  Just stick weld it, or wire weld it.  Direct the heat into the 1/4 material, and let the filler wash back into the 1/8 material.This is made using 11ga tubing attached to 3/8 plate.  All stick welded due to the strength requirements.Had the usual WeldingWeb Moron Expert try to tell me this, and the rest of the tie downs I made for this particular trailer, wouldn't be strong enough to meet DOT requirements.So, cause I'm never wrong, and just plain cantankerous, and don't like self proclaimed experts, I decided to do some QCTwas back in the day before cry babies were coddled here"Any day above ground is a good day"http://www.farmersamm.com/
Reply:And I suppose, while I'm at it  Let's bust another myth..............."6013 can't be used for structural welds"Built that front end loader way-back-when while I still ran a lot of 6013.  Seems to have held up okNow don't get me wrong, there are a lot of things that really do need 7018, but some things do just fine with 60xx filler material.It's my feeling that 90% of the strength in a structure comes from overall design.  Design includes weld joint design too.  You can't expect to hold something together just with a stronger filler material, the joint has to be designed properly too.  It's a sorta Global way of thinking.  The Sum Of The Parts sorta thing."Any day above ground is a good day"http://www.farmersamm.com/
Reply:farmersamm; what are you booming down with the rachet straps  like that ?gxbxc
Reply:Originally Posted by gxbxcfarmersamm; what are you booming down with the rachet straps  like that ?gxbxc
Reply:That's for sure ,we boomed down a pair of mixer drums on a flat bed one time ,used a BIG cheater bar on the strap winch , The driver had to cut one of the straps to get it off,went like an elastic band "Snap". To be honest I first thought this was a barbecue  tool post .gxbxc
Reply:Originally Posted by gxbxc To be honest I first thought this was a barbecue  tool post .gxbxc
Reply:Thought I was going to see one of these:
Reply:So your telling me there is a difference between a steak and a stake?Thermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Originally Posted by farmersammAnd I suppose, while I'm at it  Let's bust another myth..............."6013 can't be used for structural welds"Built that front end loader way-back-when while I still ran a lot of 6013.  Seems to have held up okNow don't get me wrong, there are a lot of things that really do need 7018, but some things do just fine with 60xx filler material.It's my feeling that 90% of the strength in a structure comes from overall design.  Design includes weld joint design too.  You can't expect to hold something together just with a stronger filler material, the joint has to be designed properly too.  It's a sorta Global way of thinking.  The Sum Of The Parts sorta thing.
Reply:Sam, the picture of the Ford is not really fair.. Since you have a Ford, you have way more practice jacking/Lifting it up then most people..Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140iYou guys are terrible. Hilarious, but terrible, .-Spike
Reply:Originally Posted by MudmanThought I was going to see one of these:
Reply:To make it better, it was seared/fried in bacon fat.
Reply:That guy is me lol. It's a chest rig made by Hill People Gear. Designed to carry a pistola, when owb or iwb isn't ideal for outdoors activity. And I can quick draw candy bars. Excellent for concealed Skittles carry as well.
Reply:Originally Posted by MudmanThat guy is me lol. It's a chest rig made by Hill People Gear. Designed to carry a pistola, when owb or iwb isn't ideal for outdoors activity. And I can quick draw candy bars. Excellent for concealed Skittles carry as well.
Reply:Originally Posted by Austin BennettSo your telling me there is a difference between a steak and a stake?
Reply:My bad
Reply:If you are iron deficient stake may be more healthy for you than steak.Seriously, I can't weld out of position with 6013, I make a disgraceful mess. 7018 works better for me vertical or overhead. In theory a piece of 6013 welded steel 1 square inch in cross section should be enough to lift a fully loaded semi trailer. Even 7018 won't lift the tractor too. Better odds of a sound weld would be my reason for choosing 7018, not the 10000 lb difference in theoretical tensile strength. By the way, who decided a MIG weld couldn't be as strong as stick?
Reply:Originally Posted by Willie B By the way, who decided a MIG weld couldn't be as strong as stick?
Reply:Originally Posted by limegreentjwell then i vote we have a bbq at your house. i'd buy a plane ticket for a steak like that!!!
GMT+8, 2026-1-2 04:20 , Processed in 0.071424 second(s), 18 queries .
