Used Hobart arc welder 300 amps slant 6 engine in Prince George, VA
发表于 2021-8-31 22:17:53 | 显示全部楼层 |阅读模式
Hobart pull-behind gasoline powered DC output welder welds and works great. Has a 110 outlet for grinder, drop light, etc. $1000 OBO. Call Mike at 804-892-7060 or 804-733-4015. Sorry, no trades. Will deliver anywhere in the tri-cities area. (Petersburg, Hopewell, Colonial Heights) Obviously, this welder cannot be shipped as it is a pull-behind welder.NOTE: I am posting this for my fiance's step-dad. He doesn't use the internet, however my fiance is knowledgable about welders and will be able to answer any questions you may have about the welder. Or, you can just call Mike at the above phone numbers.
GMT+8, 2026-1-2 04:21 , Processed in 0.097963 second(s), 18 queries .
