Lincoln SA 200
发表于 2021-8-31 22:17:52 | 显示全部楼层 |阅读模式
Lincoln SA 200 welder code 6633. A 1968, 69, or 70 model judging by the code on the side of the generator. The face plate was replaced by the previous owner and with this code number I believe it should be a red face plate. F163 engine and does not leak, smoke, or burn oil. Machine runs well, welds great, and pulls straight.  The carburetor has been rebuilt, new crank shaft bearings, gen to engine oil seal replaced, upgraded to alternator, new upper and lower radiator hoses, fan belt, and water temp gauge installed.  I have an extra starter, fuel tank cap, oil filter unit, and radiator cover. Leads and extension cord not included.  Asking $2000obo  Josh 3365773266 Located in NC. Attached ImagesAWS Certified Welding Inspector,certified welder (unlimited 3G/4G)NDT and Coatinge inspectionShieldarc 250Presion TIG 225Alpha 200xChop sawDrills / grindersband sawoxy/acetylene hand toolsEtc....
Reply:Are the spring shackles bolted or welded to the frame?
Reply:shakles are bolted and tounge also.  They are origianl pieces from LincolnAWS Certified Welding Inspector,certified welder (unlimited 3G/4G)NDT and Coatinge inspectionShieldarc 250Presion TIG 225Alpha 200xChop sawDrills / grindersband sawoxy/acetylene hand toolsEtc....
Reply:That's a Red Face... round generator. Also should be a 162 motor, not a 163... since it has the low set starter.
Reply:Originally Posted by chambiec1That's a Red Face... round generator. Also should be a 162 motor, not a 163... since it has the low set starter.
Reply:Is that a Willys Pickup in the background?Powcon 400SM2-PD60 wire feedersMiller XR controlAlumapro push/pull gunSpeedglas 9100xBFH
GMT+8, 2026-1-2 04:21 , Processed in 0.112940 second(s), 18 queries .
