MM200 Dual Tank Rack
发表于 2021-8-31 22:17:52 | 显示全部楼层 |阅读模式
I'm looking to swap the dual tank setup on my MM200 for the single tank setup.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:wonder if it would swap out with the single on my 350p where you located?350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Huntington, NY.  See if you can find out the PN for your single setup.  I think you mantain the same wheels, so shipping shouldn't be too bad.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:It definately wouldn't be a "bolt-on" converstion due to the vast differences in the machine frames configurations and sizes.  Reveiw the Parts manual/section for a comparison to see whatI'm talking about.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-2 04:21 , Processed in 0.090163 second(s), 18 queries .
