Lincoln Idealarc 250
发表于 2021-8-31 22:17:52 | 显示全部楼层 |阅读模式
Do y'all know if this is worth 250 to 300 dollars? Attached Images
Reply:Looks to be in good shape. Yes, it's worth that much. Try to get it for closer to $200 if possible. Those are great machines. I restored one earlier this year. You can't really kill one of those things.PapaLincoln Idealarc 250 (circa 1962)Lincoln Weldpak 155 w/Mig KitLincoln Squarewave TIG 175
Reply:I'd give 250 for it and I don't even need one.
Reply:All day long buy it.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Bullet Proof welders they weld  and weld  and weldidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Thanks for the input. I'm the same way, I don't really need it but I'm thinking I should just go buy it.
Reply:Excelent stick welder. Good scratch start dc tig welder as well.Good duty cycle. Almost bullet proof.A machine you can arc air with.Will burn any stick electrode you can throw at it.Preaty versitile powersource.Last edited by snoeproe; 08-25-2011 at 09:08 PM.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Originally Posted by snoeproeExcelent stick welder. Good scratch start dc tig welder as well.Good duty cycle. Almost bullet proof.A machine you can arc air with.Will burn any stick electrode you can throw at it.Preaty versitile powersource.
Reply:Tell them you want a discount for the idiot who lopped off the lifting eye from the top. Lincoln Idealarc 250 (circa 1962)Lincoln Weldpak 155 w/Mig KitLincoln Squarewave TIG 175
Reply:Originally Posted by papaharley03Tell them you want a discount for the idiot who lopped off the lifting eye from the top.
Reply:The lift eye was cut off to remove the cover.Just weld another one back on, if you need it.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Originally Posted by snoeproeThe lift eye was cut off to remove the cover.
Reply:Thats interesting because when I picked up my Idealarc, the lift eye had been cut off as well and welded back on. As mine was, it had to be cut off again to remove the cover again. The new piece was lap welded instead of butt welded back on Last edited by snoeproe; 08-27-2011 at 07:54 AM.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Snoeproe, seems to me it would be easier to widen the slot in the cover a bit to clear the lap weld.Lincoln Idealarc 250 (circa 1962)Lincoln Weldpak 155 w/Mig KitLincoln Squarewave TIG 175
Reply:Originally Posted by papaharley03Snoeproe, seems to me it would be easier to widen the slot in the cover a bit to clear the lap weld.
Reply:Originally Posted by DSWBut then you don't get to weld something! Where's the fun in that?
Reply:Well I offered him $200 and he responded by raising the price from $300 to $399
Reply:Originally Posted by GEAUXSAINTSWell I offered him $200 and he responded by raising the price from $300 to $399
Reply:You will have to up the anti.These are $2000 new and still sold by lincoln.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I'd wait. There are more out there. I tell folks who want high dollar that I hope they get it, but it won't be from me.
GMT+8, 2026-1-2 04:22 , Processed in 0.099225 second(s), 18 queries .
