查看: 2|回复: 0
Lincoln Innershield 350 gun liner question
发表于 2021-8-31 22:17:46 | 显示全部楼层 |阅读模式
How do you get the liner out of one of these innserhield guns? On the back end where the wire enters I don't see a set screw. I pulled the two set screws that hold the rear cover and spring. Is there anything holding it on the gun end?Lincoln Powermig 300Lincoln Weldanpower 250 G9 ProLincoln LN 25Lincoln AC 225HTP Invertig 201 AC/DCHarris O/A
Reply:If I am thinking of the gun you are talking about, I think those gun are like the Bernard Dura flux guns and Do NOT have a changeable liner in them. I think the only one that has a changeable liner is the Miller Ironmate. I am not sure because I dont know 100% about the Lincoln guns. Maybe someone else will know.
Reply:Lincoln innershield guns have non-replaceable liners.
Reply:Thanks.Lincoln Powermig 300Lincoln Weldanpower 250 G9 ProLincoln LN 25Lincoln AC 225HTP Invertig 201 AC/DCHarris O/A
Reply:The Innershield Guns may not have a liner in the 'main' cable, but they DO have a replaceable liner in the torch neck.Innershield 350 gun K126 uses KP2095-4 nozzle liner for the 6 inch neck.  The best laid schemes ... Gang oft agley ...
GMT+8, 2026-1-2 00:37 , Processed in 0.097472 second(s), 18 queries .
