查看: 13|回复: 0
1980 Lincoln Pipeliner 200
发表于 2021-8-31 22:17:45 | 显示全部楼层 |阅读模式
Is it possible to get 10,000 kw out of the generator section out of this machine??
Reply:The simple answer to that is no. Also any equipment you would want to run off the machine would have to be AC/DC because the pipeliner is a DC only welder generator.My vintage equipment 1957 Lincoln sa 2001980's Lincoln 225 AC1952 F-2 ford truck1957 F-250 ford truck
Reply:Ok. All you can do is just pipeline weld and run certian size power tools right?
Reply:Originally Posted by cowdogteamroperOk. All you can do is just pipeline weld and run certian size power tools right?
Reply:thank you.  im just a 18 yr old kid who rly want to pipeline weld bad but i am self tought by farm repairs n now currently in sum cheap weldin school cuz it the only option i got and they dont rly do much pipeline welding.
Reply:ok.  thank you very much..  if there any info that you would like to share it is much apperated.
GMT+8, 2026-1-2 00:38 , Processed in 0.069246 second(s), 18 queries .
