lincoln Sp130t welder problem
发表于 2021-8-31 22:17:45 | 显示全部楼层 |阅读模式
I have a Lincoln sp130t mig welder and I have no voltage at the wire feed motor leads. The fan runs, the gas solenoid opens when I squeeze the trigger. I just bought a new PC board for it and it still doesn't work.    If anyone has any ideas please let me know.                          Thanks
Reply:Have you tried hooking a voltmeter up to either end of the gun (ie plug end, and diffuser end)? You should get a readout from either. Have you checked the parts guides on Lincolns site? You can find your machine breakdown using the 5 digit code number on your machine. Might help you discover a problem.My rod is hot, and it penetrates deep.
GMT+8, 2026-1-1 23:04 , Processed in 0.096053 second(s), 18 queries .
