How to DIY Shielding gas mixing or blending...
发表于 2021-8-31 22:17:36 | 显示全部楼层 |阅读模式
Can you show your setups for mixing or blending your own shielding gasses?   Thanks!I will be needing C25 and 90/10 or 92/8 Argon/CO2 mixes with my new Millermatic 350P and Argon for aluminum and TIG with the possibility of needing some Helium for TIG... I would like to minimize gas costs by purchasing plain Argon, CO2 and Helium and blend as needed.I have these Veriflo units that I'll need to go through to see if they are functioning properly... (the 3-way is labeled Argon-CO2-Helium)GlenMiller Dynasty 200DX - Millermatic 350P - Hypertherm Powermax 45Want to sell!! - Hobart Handler 150
Reply:Never seen those units before. Interesting concept you want to do. I blend argon and helium with identical flowmeters and output pressures for consistency but that is it.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
GMT+8, 2026-1-2 00:37 , Processed in 0.098951 second(s), 18 queries .
