I like big butt's and i cannot lie...
发表于 2021-8-31 22:17:34 | 显示全部楼层 |阅读模式
A nice 24" Sch 160 for tonightSent from my LG-P716 using Tapatalk
Reply:that took a rod or two.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Nice work! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Nice, I usually get dizzy , ok dizzier  going round and round like that. Thanks Mike for sharing one of your personal videos from your collection.
Reply:Originally Posted by BD1Nice, I usually get dizzy , ok dizzier  going round and round like that. Thanks Mike for sharing one of your personal videos from your collection.
Reply:I always think of this which was from I Living Color which I used to watch live on the air.Tim
Reply:Yike Mike, me like...get down, get roun', pretty slick like my chick,weldin' theme song az bin foun'Last edited by bearston; 10-04-2014 at 11:32 AM.When a welder tells you to "stick it", what do they really mean?"In a time of universal deceit, telling the truth is a revolutionary act." - George Orwell
Reply:To make them go quicker, just bump the amps up and put 5rods in the stinger! Nice work
Reply:24" 160 is a lot of welding. Just you, or brother in law? TIG root? I see they marked the window for root inspection for you.I hope you got a good brother in law. A bad one can make for a miserable job.
Reply:ER70S-2 TIG root, conarc 49C 7018 out, **** bro in law on this one, he's a rope maker and likes to weave, but he's  just learning, ill show  him the waySent from my LG-P716 using Tapatalk
Reply:Looks good. What size rods are you runnin on that? 5/32? Got to ask what it's for  did some 42 double x a few weeks ago  makes for and east day. One fit and turn and burn
Reply:oh jeez. nice work! how long does one of those take not counting fitup? just weldingbosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:Not sure of imperial sizes, I use 4mm fill, and 3.2 for the cap, for the 24"sch dia, 6" wall pipe we sometimes weld i use 4mm all the way, I'd use 6 (1/4") if they'd let me though36 hours work for one person on the site im on, oncluding all the saftey and QC hoops that we have to jump through.Sent from my LG-P716 using Tapatalk
Reply:6 inch wall? Good lord, better you than me.  You building a power plant? I did some 24 inch - 2 inch wall tube headers on a power plant, with the brother in law from hell.  They had a row of about 6 tubes on each side of the joint about 2 inches from the edge of the bevel. They went from about 10 o'clock to 2 o'clock. You had about 6 inches of room to get your arms in on the top, you had to run the top downhill with TIG, there was no other way to see it. Reach out as far as you could and try to TIG a root down in a 2 inch deep bevel. Some of the most challenging welds I ever had to do, didn't help when my brother in law short armed me on the top and I had to reach over on his side to start.
Reply:Man, I went round and round with that idiot on those welds. He would run his 7018 with a push angle and leave me a big glob of cold lap on top to tie into. I would have to grind it down, and he's telling me the whole time, 'Aw, you can burn that out bro.' I tell him, 'Yeah, what if it don't burn out, what then?' You'd have to gouge down almost 2 inches in a real bad spot just to get to it.' This guy was a nightmare to weld with.He tried to fill one with 5/32 all the while bragging how he was gonna smoke me. X ray showed he left a slag line about 2 feet long. I laughed my *** off, standing down on the ground watching him grind all day.
Reply:Originally Posted by TimmyTIG6 inch wall? Good lord, better you than me.  You building a power plant? I did some 24 inch - 2 inch wall tube headers on a power plant, with the brother in law from hell.  They had a row of about 6 tubes on each side of the joint about 2 inches from the edge of the bevel. They went from about 10 o'clock to 2 o'clock. You had about 6 inches of room to get your arms in on the top, you had to run the top downhill with TIG, there was no other way to see it. Reach out as far as you could and try to TIG a root down in a 2 inch deep bevel. Some of the most challenging welds I ever had to do, didn't help when my brother in law short armed me on the top and I had to reach over on his side to start.
GMT+8, 2026-1-1 23:13 , Processed in 0.098246 second(s), 18 queries .
