T Joint Help Please
发表于 2021-8-31 22:17:27 | 显示全部楼层 |阅读模式
I'm getting ready to start welding T Joints Tuesday with SMAW. I will be using 1/8" 6010 and starting in the flat position. Can some one give me a little insight on how I should weld this joint? I understand the theory behind a vertical t joint. Thanks a lot
GMT+8, 2026-1-2 00:37 , Processed in 0.101821 second(s), 18 queries .
