used a HF mini Tool Grinder http://www.harborfreight.com/3-inch-...her-94071.html took all the guard stuff off Then turned some brass stock to accept the Diamond wheel http://www.harborfreight.com/replace...ner-98862.htmlthen put a smaller diamond wheel on the end which is coarser http://www.harborfreight.com/4-piece...set-32397.htmlthen put a piece of sheet metal on the base so i can clamp it to a table Its used everyday no problems and has been in service for over a year Attached ImagesMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:I like it.Is that just the standard stone wheel in the middle of the two diamond wheels?and do you use it like a standard grinder, with the wheels rotating towards you (pulling the job into the bench) or do you use it rotated, so the tungsten is pulled away from you?again, good work.
Reply:Originally Posted by stiffmanI like it.Is that just the standard stone wheel in the middle of the two diamond wheels?and do you use it like a standard grinder, with the wheels rotating towards you (pulling the job into the bench) or do you use it rotated, so the tungsten is pulled away from you?again, good work.
Reply:that's really cool, I was going to buy that little grinder but figured I'd never be able to find replacement stones so I didn't bother, this is a really cool idea but I'd build a new guard for it I think, would also help keep the dust from going everywheremiller 330a bp TIGmiller dynasty 200DX TIGmillermatic 185 MIGthermal dynamics cutmaster 101 plasma cuttersnap-on YA5550 plasma cutterhypertherm powermax 30 plasma cutterbaileigh CS225 cold sawetc....
Reply:Originally Posted by turbocad6that's really cool, I was going to buy that little grinder but figured I'd never be able to find replacement stones so I didn't bother, this is a really cool idea but I'd build a new guard for it I think, would also help keep the dust from going everywhere |
