WeldenPower G3000 "skips"
发表于 2021-8-31 22:17:11 | 显示全部楼层 |阅读模式
My welder loses the arc if the rod isn't kept right down close. It seams like sometimes even if it is close it skips anyway. Is there something I can check or use a meter to OHM out? Never worked on a welder before. Any help is appreciated.
Reply:Do you have the unit manual to follow its troubleshooting chart?  If not, get it here http://www.mylincolnelectric.com/Cat...t.aspx?p=32924Sounds like a simple case of low output - dirty slip rings/stuck brushes, bad fine current control, low engine RPM, open diode in output rectifier. . .MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-2 00:41 , Processed in 0.072917 second(s), 18 queries .
