lincoln 180
发表于 2021-8-31 22:17:10 | 显示全部楼层 |阅读模式
where to get parts for a lincoln 180 mig  in Virginia. I need the wire drive motor and the pinion gear. this thing is brand new got it from a guy that said his brother owed him money and give it to him to sell so it might be a shadey deal so I will just buy the parts if I can find them thanks
Reply:http://www.mylincolnelectric.com/Cat...ualsearch.aspxEnter in the Model number and Code number.You can get  Parts breakdown as well as a manual then all you have to do is go to your LWS and have them order the Parts.Might be able to order directly from Lincoln too.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2026-1-2 00:37 , Processed in 0.068166 second(s), 18 queries .
