216 Power Mig
发表于 2021-8-31 22:17:10 | 显示全部楼层 |阅读模式
Just bought my new machine and have a question. If I need to change the liner in the gun if I am going to use .030 wire all the time? Is there anything else I should do. I did change the roller drives. Thanx  Jeff
Reply:I've never found the need to change yet. I suppose that if you knew for certain that you were never going to go larger than .030, then you might get a slightly more consitant feed at warp six using the smaller liner. The feed system is such that there are very few problems to begin with. Personally I think you are going to find you will want to run some .035 &/or .045 flux core sooner than you think. I'd leave the liner alone unless I wanted to try some .023 solid."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
GMT+8, 2026-1-1 23:13 , Processed in 0.076677 second(s), 18 queries .
