2a200 issue
发表于 2021-8-31 22:17:07 | 显示全部楼层 |阅读模式
Hello all, I just pulled one of my sa200s out that i have not ran in a year or so, it runs great and will excite off the 110 outlet but will not excite when trying to strike and arc. I am thinking it might be the reed switch but am unsure, any help would be greatly appreciatedthanksJeremy
Reply:Yes, it could be the reed switch.  Make sure it has a good ground to the chassis and if your idler board is the type that has a spade terminal for the reed switch lead (red wire) rather than hard soldered, make sure it is getting good contact too.You can check the board operation by grounding the red lead.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:thank you sir, i will check that first thing in the morning, neighbors arent too thrilled about the straight pipe sound at night lol
Reply:Maybe find a used muffler can slip on it when needed and take back off ? lol   IM-277-A can be downloaded from Lincoln has trouble shooting chart on pages 10 & 11.http://content.lincolnelectric.com/p...m/obsomenu.pdfhttp://www.mylincolnelectric.com/Cat...ualsearch.aspx
GMT+8, 2026-1-1 23:04 , Processed in 0.073974 second(s), 18 queries .
