pure dc
发表于 2021-8-31 22:17:06 | 显示全部楼层 |阅读模式
Hey guys I have been looking at sae welders and cant help but wonder sa200,250.300are pure dc using a dc exciter but the 400 uses a a.c. exciter does the 400 only use vthe a.c. for the 120 outlet or is this basicil a big alternator like the millers? I realize the older ones had aluminum but other than that do they weld as good as sa200 ? Any info is appreciated.
Reply:nothing welds like a red face sa 200
Reply:thats what they say but is there a reason?
Reply:B1det - FWIW, the 250 has an AC auxiliary. The AC output is rectified to DC for the main generator's exciter current.Hope it gets you closer.Good Luck
Reply:So does this mean the arc is actually as rectified to dc?
Reply:Originally Posted by b1detSo does this mean the arc is actually as rectified to dc?
Reply:Thank you very much.
Reply:Originally Posted by b1detthats what they say but is there a reason?
Reply:Originally Posted by b1detHey guys I have been looking at sae welders and cant help but wonder .........
Reply:I have an old lincoln SAE 300 welder and it has an old Hercules gas 6 cylinder engine running it, are you sure this is correct Attached Imagesbrentc
Reply:Thank you everyone for your reply's .
Reply:Seems like we've covered this ground before. I too had thought that "E" was for Electric.I believe it was member Weldersales who posted that "E" was for Enhanced, referring to the dual continuous control.Good Luck
Reply:Originally Posted by denrepSeems like we've covered this ground before. I too had thought that "E" was for Electric.I believe it was member Weldersales who posted that "E" was for Enhanced, referring to the dual continuous control.Good Luck
Reply:SA or SAE they both weld mighty fine.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Checking the Lincoln website manuals, they appear to have come in engine, AC motor and DC motor drive configurations...........
GMT+8, 2026-1-2 00:41 , Processed in 0.072818 second(s), 18 queries .
