Question about finishing up a fireplace grate
发表于 2021-8-31 22:16:55 | 显示全部楼层 |阅读模式
Once the mill scale has been ground off at the weld joints and it's been welded together, what's the best way to make it all black again? It's for a customer, not personal use, otherwise I'd just start using it as it. Grill paint? Engine paint? Something else?
Reply:Do you mean a grate that holds the logs during burning?  Or something decorative?Won't matter if it's for burning in my opinion - heat will take it right off.If it's decorative - "sand" blast to an even finish and then paint is how I do smaller stuff like that.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:For presentation?  Heat it up and season it with cooking oil.
Reply:It holds the logs up. Commercial ones have some kind of finish on them, they're solid black. I thought grill or engine paint might work since they're made for heat. I don't know if oil will turn shiny back to black?
Reply:for your purpose just hit it with some high heat bbq paint. oil will keep it shiny-ish its will darken with time.
Reply:OK, thanks.
Reply:Use some hi-heat paint.  If it burns off, the metal will be heated to blue or dark gray and will blend in.  Just a way to make it less raw looking when new."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
GMT+8, 2026-1-2 04:21 , Processed in 0.099942 second(s), 18 queries .
