anyone recognise this lincoln?
发表于 2021-8-31 22:16:54 | 显示全部楼层 |阅读模式
saw this for sale - anyone recognise it?tempted : )down under Attached Images
Reply:Lincwelder of some sort.  Similar to this:"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:yes, I think that sheds some light on it. thanks!
Reply:The engine retrofit has to be a poor match for the original's speed and power-band.If revved up I wonder if it couldn't  overspeed the generator and sling its windings?
Reply:I believe by the looks of what's left of the lettering on the name plate it is actually an sa200 junior.
Reply:Probably not a lot of difference between a Lincwelder 250 and an SA200 Junior.  If I had to guess, I'd say the SA200 Junior was close to a Lincwelder 250 but renamed/rerated.  It would capitalize on the SA200 reputation, as opposed to the smaller Lincwelder 180. (One of my sources of info is a product flyer inserted in my 1959 reprint of the Lincoln Handbook of Arc Welding Design and Practice.)"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:It would be a fun project if a guy had a little Kubota diesel off of a reefer or something. As for restoration and actual use, it would cost more than it would ever be worth to me. Even if it were almost free.
Reply:yes tuff resto!
Reply:I believe that V4 Wisconsin is a 3600rpm engine?Its been a long time since I have been around one.
Reply:Pipeliner is probably right about it being a SA200 Junior.  Looks like it may have preceded the Lincwelder 250 AS."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
GMT+8, 2026-1-2 02:51 , Processed in 0.067137 second(s), 18 queries .
