Lincoln V300 Pro to Miller S-22P12 connections
发表于 2021-8-31 22:16:54 | 显示全部楼层 |阅读模式
Can someone verify that I can connect these two with a homemade remote patch cord?Invertec is capable of 24v output?I think this is how it should be but am not sure....Miller to LincolnA to NB to 4G to 2C to 77D to 76E to 75Any help would be much appreciated!Thanks
Reply:Anyone?
Reply:Here are the schematic diagrams That I found, miller wire feeder, lincoln v300 pro. I do not see 24vac coming out of the lincoln, so you will need a separate 24vac transformer to power the millerlincoln to miller remote voltage pot77 E--------C76 F--------E75 G--------Dthe lincoln wire feed connector appears to be DC
Reply:the transformer should have about 4Amps  based on what the wire feeder requiresLast edited by sparkness; 10-14-2014 at 04:05 PM.
Reply:http://www.lincolnelectric.com/asset...oln3/IM526.pdfPage 23 shows terminal N or spare having 24V
Reply:I see that, but it also has only one amp, this may work fine provided you do not use a very long wire feed gun . Also the manual I downloaded did not have that diagram. here is a Revised DiagramLast edited by sparkness; 10-15-2014 at 12:21 PM.
GMT+8, 2026-1-2 02:38 , Processed in 0.137138 second(s), 18 queries .
