Tig torch lube
发表于 2021-8-31 22:16:53 | 显示全部楼层 |阅读模式
Is it common practice to lube the o-rings on a torch?  If so, what is the recommended lube?  Thanks!
Reply:Nope.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:O ring lube. I use silicone grease.
Reply:Never really thought about it, but I have one of those little flip-top lid containers of Vaseline in the tool box for automotive stuff - I just use that sometimes so the o-rings don't grab.Use it on my slip on mig nozzle too.If there is a more correct product, I'm open to switching.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Just a little spit will help the back cap seat in place without pushing the o ringAirco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:I use the same stuff I use on my oxy/acet tips, I 'lick' them. Good ole spit!
Reply:Originally Posted by SquirmyPugJust a little spit will help the back cap seat in place without pushing the o ring
Reply:Originally Posted by MinnesotaDaveBunch of rednecks!   Now where did I put that adjustable wrench... I need to use it as a hammer...
Reply:Originally Posted by SquirmyPugI just used one as a hammer 20 minutes ago
Reply:Spray a slight amount on o-ring and threads of backcap and let dry. Be careful not to get any inside backcap.Works especially well on air cooled torches.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:What's the carrier in that dry lube?  Lots of them can eat rubber o rings.
Reply:Originally Posted by shovelonSpray a slight amount on o-ring and threads of backcap and let dry. Be careful not to get any inside backcap.Works especially well on air cooled torches.
GMT+8, 2026-1-2 04:22 , Processed in 0.101695 second(s), 18 queries .
