Victor 100 series torch
发表于 2021-8-31 22:16:52 | 显示全部楼层 |阅读模式
Hi, I just picked up this 100 series torch from an auction, and was wondering how I would find out what tips to buy for it.
Reply:Victor's website.  http://victortechnologies.com/victor/
Reply:I have a Victor 100.  It uses __-W-1 tips (000-W-1, 00-W-1, 0-W-1, 1-W-1, etc.)  The tip sizes go up to 7, but make sure you don't buy a tip size larger than your acetylene bottle can supply (I only have tips through 5-W-1 for my 145 Cu Ft bottle).the rosebud heating tips are MFA__ (I have MFA 4 & MFA 6)KevKevin / Machine_Punk from The Aerodrome Studio - Lincoln PowerMIG 210 MP - Meco N Midget w/custom welding station - Vintage Victor 100Current Projects: The Aerodrome Studio
Reply:And make sure you pickup flashback arrestors while you are at it.  I have that torch, though a newer model.  Works well.Dynasty 280DXCoolmate 3Lincoln AC 225 TombstoneVictor Oxy/acetylene
Reply:Yes the torch came with check valves which is nice, thanks for the tips guys.
Reply:Originally Posted by ForgeweldYes the torch came with check valves which is nice, thanks for the tips guys.
Reply:Originally Posted by vwguy3Check valves or flash back arrestors?.....seems like they would be the same but they are not.
GMT+8, 2026-1-2 04:44 , Processed in 0.071929 second(s), 18 queries .
