Any problems with new miller 252 migs
发表于 2021-8-31 22:16:51 | 显示全部楼层 |阅读模式
Well you guys steered me in the right direction with my last purchase of torches so I figured i'd consult you again and see what you think. I've been looking at and researching the new millermatic 252 migs. I ran 250's at my last job and they were good machines so I'm pretty sure I'm going to get a 252. But just wanted to know if if there was any problems or design flaws with the new ones. Read some stuff on the internet some people said there perfect others said they had problems. just trying to get some more opinions.thanks in advanceJustin
Reply:In my opinion the best 250-300 amp might welder out there. The only issue I had was the M-25 gun. If you plan on using dual-shield or spray arc it won't last long, replaced mine with a Bernard Q-300.
Reply:Originally Posted by M J DIn my opinion the best 250-300 amp might welder out there. The only issue I had was the M-25 gun. If you plan on using dual-shield or spray arc it won't last long, replaced mine with a Bernard Q-300.
Reply:I got a few of them off of eBay for less than $100 a piece otherwise 250-300 at a LWS.
Reply:I like mine. welds beautiful
Reply:I have not personally used one but I have heard several people say that they like the older 251 better than the 252. They are good reliable machines and I wouldn't worry too much about buying used.The Lincoln 255XT and Thermal Arc 252i are also very nice if you are not set on buying blue. JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:Had my 252 for right about a year and absolutely no issues. Very good arc and has plenty of power for what goes through my shop. Works much better with my 30A spool gun than my 250X did.Miller Dynasty 200DXMiller 252 Miller 250xMiller Syncrowave 250Miller AEAD200 LegendMiller 375 Xtreme plasmaLincoln WeldPak 100Victor O/A
Reply:Finally went down and picked one up today. Now I just have to get some wire and new outlet to plug it in. Total came to $3046 with machine, rental and deposit for argon/co2 mix big tank, spool of .035 lincoln wire,  and new digital auto darkening hood. Cant wait to try it.
Reply:I don't own one, but I've used a 252 several times at a friend's shop.  Sweet machine.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:I've had mine for about a year and it's been fantastic.   I've only run er70s-6 through mine and short circuit.   Perhaps one day I'll get a spool gun or push/pull for it but I don't do much aluminum.   It's got a smooth arc and plenty of umph for thick stuff and good duty cycle for thinner stuff.I broke mine in on some 16ga and 14ga steel and thought the machine was broke because I couldn't get the fan to kick on.  So i cranked it up and burned on some 1/4" for awhile and it finally kicked on.  Let us know how you like it.Ben
Reply:Only problem I have had is that I didn't order it sooner .Millermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:Ya can't wait to try it that's today's project is wiring up an outlet to plug it in and start burning.
Reply:Well I didn't forget about you guys just been busy welding away and working my day job so havent had much time got a few im portant projects done like fixing my firewood processor's wedge and some cracks it developed and some stupid stuff that has come up. It probably hasn't paid for itself yet but it sure feels like it every time I have something pop up that needs some welding. Ill try and get some pics up soon of what I did I got the big important projects coming up soon. And you guys were right I already melted that plastic piece that holds the cone on.
GMT+8, 2026-1-2 04:20 , Processed in 0.101748 second(s), 18 queries .
