3500 HD for sale
发表于 2021-8-31 22:16:50 | 显示全部楼层 |阅读模式
I have for sale a 1998 GMC 3500HD.  It is a 6.5 diesel with a 5 speed.  Flatbed with a place for 2 oxygen or c25 size bottles and 2 acetelene bottles and a vice mount on back.  It has tabs for bolting  the Classic II that was on it.  Gooseneck ball under a door and reciever hitch on the back as well as light plugs.  About two years ago I replaced the PDM electronic pump with a manual pump to insure it would be dependable.  The A/C is cold and had a compressor and dryer fall of last year and front pads saturday afternoon.  The mileage is around 216,000 as I still use it, sometimes daily under a gooseneck.  It comes with a spare tire Been a good truck for me,  replaced it with a 4wd 3500.  I don't drive it hard and it gets me around 18 mpg.  I need $4500 out of it,  let me know if anyone needs more pics or has questions. It is located in south Alabama. Attached ImagesLast edited by sa 200; 06-13-2011 at 09:40 PM.
Reply:Man that truck does have some potential. I can't pick it up at the moment, but I will drop you a line in a couple of months and see if you still have it.72 Chevy Cummins Project94 3500HD Welding Rig build Sold NOV 2011
Reply:I need to move this one, got  the truck replacing it out of the paint shop tuesday.  Might consider a shorthood or 200 parts machine on trade.
Reply:is it still for sale
Reply:It is still for sale.
Reply:I am new here, is this truck still available?
Reply:Yes it is .  I tried to call you back,  give me a call when you get time.   Thanks,  Ben
Reply:This truck is sold.
Reply:Now if i can figure out why it won't go 65mph up the hills on the interstate...... without a trailer or anything on the bed. I have a 350ci gasburner and automatic in a Suburban that takes hills better, with 1800 lbs in it.If anyone knows the history of the truck, or has a hunch, i'd like to hear of it.I'm going to put a intake manifold vac/pressure gauge on it, a fuel pressure gauge on the injector pump input, and a vac gauge somewhere around the vac pump. I don't know if it is fuel starving or the turbo isn't running. Or?
GMT+8, 2026-1-2 02:41 , Processed in 0.142169 second(s), 18 queries .
