new dynasty 200 today
发表于 2021-8-31 22:16:46 | 显示全部楼层 |阅读模式
Got a new dynasty 200 with contractors kit at my local weld supply. Messed with it for about 2 hrs.  I watched the intro video with it and have a question. First of all DIG for stick welding from what the video said it helps to keep the rod from sticking? How so?Miller Pro 300 SS w/ cat Miller Bobcat 250Miller Diversion 165 Miller 211Miller Xtreme 375Miller 12vsMiller Dynasty 200 DX Miller Passport Plus w/ Spool GunMiller 30a spoolmaticLincoln AC225 Buzz Box VictorMathey Dearman - H&M
Reply:the dig function lets you fine tune how much penetration you get at the same amperage. It makes the arc have more or less force. helps when doing stuff like v groove pipe welds and full pen stuff. The more dig you add the stiffer the arc becomes and less likley to snuff out if you crowd the puddle or need a little help with your starts. Stick welding with the dynastys takes a little getting used to.
GMT+8, 2026-1-2 02:29 , Processed in 0.110998 second(s), 18 queries .
