square wave 175 problem?
发表于 2021-8-31 22:16:43 | 显示全部楼层 |阅读模式
I was tig welding some 1/8" steel and in the middle of the weld, the torch started arching and quit welding.
Reply:More info needed.Tungsten size?Amperage?Argon flow rate?Filler metal size and grade?Is your arc length consistent, or are you lifting the tungsten up from the puddle as you travel? RexLast edited by rode2rouen; 03-30-2010 at 09:10 AM.Reason: speelage
Reply:same questions plus arcing from where?
GMT+8, 2026-1-2 00:43 , Processed in 0.074880 second(s), 18 queries .
